Métier : Pilote de Brousse avec Bob Cadi.
Re: Métier : Pilote de Brousse avec Bob Cadi.
Messagepar Louis_greniier » Lun 12 Fév, 2018 22:56
Incroyable aventure !!
Bravo
BRP-Powertrain
Maintenance Manual
5.2) Preservation of an engine which has been in operation
Due to the special coating of the cylinder wall, the ROTAX aircraft engine normally needs no extra protection against corrosion.
■ CAUTION: Maximum storage period 12 months if the listed precautions are taken!
– Oil change see latest issue Maintenance Manual (Line Maintenance) for the respective engine type, 912 Series or 914 Series.
– On the ROTAX 912 Series: Run the engine to allow it to warm up, leave it running at increased idle speed, remove the air filters and inject approx. 30 cm3 of preservation oil into the carburetors, shut down the engine.
– On the ROTAX 914 Series: Remove the top spark plugs from all four cylinders and spray preservation oil into the cylinders through the spark plug bores.
Turn the crankshaft several times.
Fit spark plugs and spark plug connectors.
– Drain carburetor float chambers.
– Apply engine oil to all linkages on carburetors.
– Close all openings on the cold engine, such as the exhaust pipe, venting tube and air filter intake against entry of dirt and humidity.
– Spray all external engine steel parts with preservation oil.
– In the event of longer out of service periods repeat the whole preservation procedure annually.
Messagepar drapo » Lun 12 Fév, 2018 23:19
RESPECT Bob! ;)p
Je vais sûrement suivre de près tes prochaines aventures,
Pour les adaptateurs, un magasin CAA ou Amazon: https://www.amazon.ca/Orei-WP-I-GN-Univ ... +australia
Et si la p’tite dame sur la photo cherche des volontaires pour se pratiquer, étant maintenant retraité, je peux certainement me libérer ! :siffle:
drapo
Identification de l'avion: C-GJDP
Messagepar Bob Cadi » Lun 12 Fév, 2018 23:59
Merci Louis
Pour tes recherches.
Juste que mon nouveau Caddy à un EXP-Lycoming 0-360 de 180 hp
Mais j'imagine que le processus soit similaire.
Messagepar C-GBVK » Mar 13 Fév, 2018 01:36
Ton moteur c'est des cylindres mecaseal et un roller cam (mecaseal c'est comme les Rotax 912 )
c'est déja mieu que un cam a plateau et des cylindres sur acier
Si c'est pour long arrêt de 6 mois et plus
Tu devrais aller chercher de l'huile de storage , tu vidange et tu remet l'huile de storage tu fait tourner le moteur pour en envoyer partout , certain laisse refroidir l'huile , remette le moteur en marche et avant que l'huile se réchauffe le font marcher un court instant a 2000 rpm et l'arrête pour envoyer de l'huile épaisse sur le cam qui est en haut dans les lycoming , maintenant chacun a ses petits trucs pulveriser de l'huile de storage dans les trou de bougie et brasser l'hélice pou renvoyer sur le soupape et queue . D'autre bouche tous les trous échappements et admissions ,reniflard , pose des bougies désicantes .
Personnelement une fois bien huiler a l'huile de storage c'est inutile de le mettre en marche en statique periodiquement .
Si tu regarde le nombre d'heures de marche versus les années , il n'a pas voler beaucoup .
j'aurrai aimé avoir ce moteur dans mon avion . Puissant économique pour 180hp deux P_Mag 2100rpm il vibre pas .
Chez candiane tic tac il se vend une canette d'huile de storage que tu peux pulveriser dans tous les trous , y compris en arriere du vilbrequin et les parties métallique visible . Ne laisse pas du carburant autos dans le carburateur et réservoir et le circuit dévisse la bouchon 1/4 pipe en bas du carburateur et vide le , du 100LL dans le carburateur même un an arreté ne fera pas de gomme .
Messagepar ttq » Mar 13 Fév, 2018 08:11
c'est ce que je disais, j'en ai de la gratos....
Messagepar tonyb » Mar 13 Fév, 2018 09:13
Pour adaptateur 220, si tu passe a Montreal va chez Addison vraiment pas cher.
tonyb
Messagepar C-GBVK » Mar 13 Fév, 2018 11:00
tonyb a écrit:Pour adaptateur 220, si tu passe a Montreal va chez Addison vraiment pas cher.
Addison Drumonville c'est moins loin pour Bob.
Mais ne pense pas connecter un seche cheveux ou fera repasser :o
Bien mal au milieu de nul part pris tu peut utiliser un ondulateur de qualité qui part de 12 volts a 110 AC batterie
Certains ordinateurs de sécurité que en cas de manque électricité fonction en permanance sur ce principe .
Messagepar Bob Cadi » Mar 13 Fév, 2018 12:57
Messagepar jocecady » Mar 13 Fév, 2018 15:44
Bob Cadi a écrit:Un peu de culture.
http://www.mackoo.com/fiji/avant.htm
Propreté : Exemplaire. On s'attendait à des problèmes compte tenu des conditions parfois précaires, mais rien à craindre.
Certains règles, pas de tatoo, pas de piercings, barbe faite tous les matins, tenue propre voir impeccable.
Bob tu peut laisser tes botte a cuisse ici a moins qu'il soit faite en peau de crocodile hi hi :mrgreen:
Jocelyn
jocecady
Messagepar air » Mar 13 Fév, 2018 21:01
C’est très généreux de partager. Merci de partager tes aventures.
air
Messagepar Frank KKB » Mer 14 Fév, 2018 09:43
Merci Bob
super intéressant, je me suis encore instruit ce matin :thumbup: :thumbup: :thumbup:
Frank KKB
Modèle de l'avion: Arrow II
Messagepar Bob Cadi » Jeu 15 Fév, 2018 00:06
Voici la liste de mes principales destinations de scheds.
22 Resorts à apprendre par cœur et connaitre les places ou amerrir et décoller.
En plus des autres endroits non officiels.
Vive le GPS...
Le tout dans un environnement contrôlé-Anglais.
Image.
Départ non officiel le 26-27...
Messagepar tonyb » Jeu 15 Fév, 2018 22:00
Vraiment cool!
Félicitations!
tonyb
Messagepar Bob Cadi » Ven 16 Fév, 2018 10:28
:tapemur: :tapemur: :tapemur: :tapemur: :tapemur:
Les 12 travaux d'Astérix.
Hier, le chef pilote me demande un dernier ( 4e fois de dernier ) document.
Soit: une License Validation Certificate...for an oversea job...
Bon, qqe tel à TC...
Et je me ramasse avec une adresse courriel de 53 caractères à envoyer ma demande.
Après 3 essais, l'adessse est toujours invalide... :evil:
J'ai repris le tel ( Faites le 1-2-2-2-3-1-1 ) et je vais tenter de me faire E-mail le liens...
Osti que je commence à être ..................
Pi je connais la suite...,
Va y avoir un foquage car j'ai repassé mon médical #1 semaine passée...
Donc TC n'auras surement pas mon dossier à jours...
Donc ma license sera bonne mais pas valide...
Au secour !!!
Bob :arrow: :tapemur: :tapemur: :tapemur: :tapemur: :tapemur: :tapemur: :tapemur:
Messagepar jacdor » Ven 16 Fév, 2018 10:58
Je ne comprend pas ton dilemme ici, Licenses bonne mais pas valide????
Ton medical est passe et signe/extamper dans ta license donc bonne et Valide. N'oubie pas de payer quand la facture arrives. lol
JD
jacdor
Messagepar Bob Cadi » Ven 16 Fév, 2018 13:06
Exactement.
Le dilème c'est que TC n'auront probablement pas eu le médical de la semaine passée dans leurs dossiers mis à jour.
Vu que tout est long...tsé veux dire.
Alors, selon leurs documents je ne serai pas '' Commencial ''.
Oui j'ai l'étampe et tout le tralala ;)p , mais chef pilote veut pas voir ma license estampée.
Il veut avoir un document de TC intitulé '' License Validation Certificate ''....qui prouve que tout est conforme et valide.
Pas une copie du ECG et du médical signé.
Alors à la minute ou on se parle, dans leurs documents au system , mon médical sera échu...
Je vais rester positif, mais je ne serais pas surpris que la merde soit pognée dans ce dossier.
Qui est pourtant simple....
Je vais allumer un lampion.
Par contre, cette demande ne retardera pas mon départ...aux dires du Chef pilote. ( Fiou )
Bonne journée quand même... je viens de recevoir un colis de Addison Drummondville.
Mon transfo et mes adaptateurs canada/Fudji..
Yé !
Messagepar jacdor » Ven 16 Fév, 2018 13:52
Ok je peu comprendre ca, Tres peu de Pays acceptes le medical du Pays d'ou tu viens, il faut qu'il fasses un profit eux aussi.
Mais je sais aussi que (j'en connait deux) il y as des pilotes qui sont rendue a l'etranger pcq il ne passait pas le medical ici au Canada. Donc certaines compagnies ne prendront pas de risques d'avoir un probleme avec ca chez eux. Si il acceptes le médical du Canada alors encore mieux.
JD
Note: En fait, un des deux pilotes en question est décéder dans le pays ou il travaillait, collision entre deux helicos sur un feux de foret.
jacdor
Messagepar Bob Cadi » Ven 16 Fév, 2018 16:20
Super service rapide de TC. :danse1:
Viens de recevoir le PDF du document demandé.
Mais tel que prévu, mon médical de Juillet 2017 est échu en début Février 2018 .
J'ai par contre préciser que je pouvais leur fournir les coordonnées du Doctor.
Et que je pouvais aussi leur faxer les documents , étampés, signés et datés.
Voilà
Me n'était pas trompé mon naffaire......commence à connaitre ça la bureaucratique... ;)
A suivre..
Messagepar marmotte79 » Ven 16 Fév, 2018 18:05
en plus ton document doit être envoyé par la poste.... cela ajout du délai.. même si on est en 2018 ;)
je te souhaite un bon trip et merci de prendre tout ce temps pour partager..
Christian
marmotte79
Messagepar Bob Cadi » Ven 16 Fév, 2018 19:11
Merci.
A date, les scans et photocopies en mode photo servent de méthode de transfert.
La poste reste un autre moyen de seconde classe.
Mais, oui il m'est demandé de fournir plusieurs docs originaux à mon arrivé.
Je passe à tellement d'étapes et de changements de dates prévues que je me dit maintenant afin de ne pas pogner les nerfs
que je suis dans une méga arnaque et que si ça se réalise pour vrai, alors tout ce sera bien déroulé.
Donc, quand une personne ( incluant mon boss ) me demandent quand je vais partir, je réponds :
Peut-être un jour... :lol: :lol: :lol:
Tiens, je viens de recevoir mon permis de conduire international... ;)p
Et le transformateur qu'André m'a conseillé.
Je vais écrire à Chief Pilot pour lui poser qqe questions ...dont pourquoi son choix s'est arrêté sur moi ?
PrécédenteSuivante
