Service Bulletin pour "VAN'S AIRCRAFT" RV-6/6A, 7/7A, ...
Messagepar Hélicopter » Ven 17 Juin, 2016 21:39
A tous les propriétaires d'avion "VAN’S AIRCRAFT" RV-3, 4, 6/6A, 7/7A, 8/8A, 9/9A, 10, and 14/14A
L'EXPERIMENTAL AIRCRAFT ASSOCIATION (EAA) vient de publier sur leur site Internet un Service Bulletin d'importance pour les avions de la compagnie VAN'S AIRCRAFT.
Ce Service Bulletin demande une inspection visuelle avant le prochain envolé.
Ça concerne une fissure potentielle sur le longeron arrière (wing aft spar web) au niveau du point d'attachement des rivets de la penture intérieur des ailerons (inboard aileron hinge bracket attach rivets). Voir ci inclus :
Trouvé un aperçu en Anglais émit par “VAN’S AIRCRAFT (en Anglais seulement).
Synopsis: Cracks have been found radiating outward from the lower or upper most rivets that attach the inboard aileron hinge brackets to the webs of the wing rear spars. See Figure 1. On RV-10 or RV-14/14A aircraft, there is a potential for cracks in the flange bends of the inboard aileron hinge brackets (though there is no record of any at the time this S.B. was issued)
Time of Compliance: Inspect before further flight.
- If no cracks are detected, re-inspect at every annual condition inspection or until the modifications required by this service bulletin have been completed.
- If cracks are detected, the modifications required by this service bulletin must be completed before further flight.
VAN’S AIRCRAFT: SERBICE BULLETIN 16-03-28 (RÉSUMÉ)
SERVICE BULLETIN 16-03-28 Date Released: May 6, 2016 (Initial Release) June 2, 2016 (Added Note, pg.11) Date Effective: May 6, 2016
Affected Models: All RV-3, 4, 6/6A, 7/7A, 8/8A, 9/9A, 10, and 14/14A aircraft.
Subject: Cracking of wing aft spar web at the inboard aileron hinge bracket attach rivets. In addition, for RV-10 and RV-14/14A aircraft, there is a potential for cracking of the flange bends of the inboard aileron hinge brackets. Required Action: For RV-3/3A/3B, 4, 7/7A, 8/8A, 9/9A aircraft: Inspect for cracks as described in this document. If cracks are present in the spar web, stop drill the cracks and install aileron attach doublers as described in this service bulletin. For RV-10 and RV-14/14A aircraft: Inspect for cracks as described in this document. If cracks are found in the spar web or the inboard aileron brackets, stop drill the cracks in the spar web (if present), install aileron attach doublers, and replace the aileron hinge brackets with updated brackets. It is unlikely that RV-6/6A wings will be affected. If cracks are present in RV-6/6A aircraft, email Van’s Engineering Dept for instructions, with photos of the cracks, for a specific repair scheme. Contact Van’s Aircraft to obtain the parts needed to complete this modification for your specific model. See the SB kit part numbers at the end of this document
[b]Synopsis:
Time of Compliance: Inspect before further flight.[/b]
These kits contain the parts and hardware necessary for individual RV models to perform this SB. Order the kit for your RV.
There is a nominal charge for these kits to cover the cost of materials:
-RV Model PART NUMBER RV-3/3A/3B SB 16-03-28-3,
-RV-4/6 /6A SB 16-03-28-46,
-RV-7/7A/8/8A SB 16-03-28-78,
-RV-9/9A SB 16-03-28-9,
-RV-10/14/14A SB 16-03-28-1014.
J'espère que vous nette pas affecté?
A+
Hélicopter
Re: Service Bulletin pour "VAN'S AIRCRAFT" RV-6/6A, 7/7A, ..
Messagepar Mooney21 » Dim 19 Juin, 2016 10:57
Inspection complétée le mois dernier et tout est OK. Les avions avec problèmes sont excessivement rare. Je crois que l'on peut les compter sur les doigts de la main.
Michel
Mooney21
Messagepar Closterman » Dim 19 Juin, 2016 11:48
A ce que j'ai lue sur VAF, il y en aurais seulement 3-4... En tout cas, le mien est ok, j'ai même pas 40h de vol !! ;)
Closterman
Modèle de l'avion: RV-7A
Identification de l'avion: C-GMYL
Messagepar Hélicopter » Mer 29 Juin, 2016 07:24
Messieurs,
C'est ordinairement tous que ça prend (en avoir 3 ou 4 rapporté aux autorités (FAA ou TC)) pour émettre une « Directive Aéronautique (Airworthiness Directive (AD)).
A+
Hélicopter
Messagepar GVFR » Mer 29 Juin, 2016 10:13
J ài verifier les attachements et tous est ok sur mon RV4. Transport Canada normalement ne produit pas de consigne de navigabilite(AD) pour les constructions amateur. Il en tiens a nous de valider ces bulletins. sur le site de Vans, il y a un onglet qui donne tous les bulletins sur chaque type
d appareil Vans.
Bonne journee :mrgreen:
Michel
GVFR
Modèle de l'avion: RV4
Identification de l'avion: GVFR
Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 4 invités
