La fin du MOGAS est proche aux États-Unis (2017 ?).
Messagepar Hélicopter » Lun 19 Déc, 2016 15:40
L'Agence de Protection de l'Environnent (EPA) a publié dans un pamphlet que l'approvisionnement de l'essence automobile sans alcool (appelé dans l'aviation MOGAS) aux États-Unis approche la fin.
L'EPA poussera pour une essence de type E0 – E10 (E10 = 10% d'éthanol). Ceci, semble-t-il poussé par le puissant lobby de l'éthanol.
L'EPA, semble poussé pour débuter en 2017?
Vous trouverez plus bas l'article en anglais de « AVWEB »
End Of Mogas Near?
By Russ Niles
A publication for antique car buffs is reporting the Environmental Protection Agency is intent on ending the production of ethanol-free gasoline, known in aviation as Mogas. Hemmings Daily said the Renewable Fuels Standard issued by the EPA a couple of weeks ago sets eliminating ethanol-free gasoline as a goal. It quotes the EPA as saying it plans to “continue incentivizing the market to transition from E0 to E10 and other higher level ethanol blends.” While the EPA doesn’t set ethanol levels in fuel, it is mandated by law to set the amount of ethanol and other renewable fuels that must be blended into the U.S. fuel supply. A powerful lobby of U.S. corn producers maintains constant pressure to increase ethanol volumes.
For 2017, the EPA increased the amount of ethanol that must be used in gasoline sold in the U.S. by 6 percent to 19.28 billion gallons, or about 10.7 percent of the total gasoline supply. Most automotive gasolines have slightly less than 10 percent ethanol and all modern vehicle engines are designed to use those fuels. Manufacturers can void warranties if a higher concentration is used in their vehicles. But there are blends that have 15 percent or more ethanol and can be used in so-called flex fuel vehicles. The threat to Mogas comes with the theory that as ethanol volumes required by the EPA increase, there is less room to allow production of ethanol-free gas because of the so-called 10 percent “blend wall” that refiners are reluctant to breach in their mainstream fuels. That means more flex fuel blends will have to be sold to absorb the increased ethanol volume.
Marine and off-road vehicle engine manufacturers are leading the battle against the demise of ethanol-free fuel because their engines and operating environments make them more susceptible to alcohol-related damage. The EPA claims ethanol-free fuel is a preference rather than a requirement for virtually all other engines, like those in old cars and airplanes, even though the FAA specifically bans the use of ethanol-blended fuels in the automotive fuel STCs it issues for certified aircraft. “With the exception of the oldest engines, essentially all vehicles and engines currently in use have been designed to be compatible with E10,” the EPA says in its response to comments opposing the increased use of ethanol. There are about 110 airports selling Mogas in the U.S., according to the website flyunleaded.com. Many more aircraft owners buy Mogas at gas stations and fill their tanks from jerry cans at considerable cost savings.
Hélicopter
Re: La fin du MOGAS est proche aux États-Unis (2017 ?).
Messagepar ttq » Lun 19 Déc, 2016 18:38
de la vraie BS....juste les puissants lobbies peuvent influencer les pôvres politiciens sans connaissances
et en plus c'est prouver partout que l'éthanol coute cher en polution
accapare beaucoup de terre, prends des tonnes d'engrais...qui polue l'eau
en plus de faire baisser le rendement du moteur
pas une bonne politique selon moi
j'avais calculé de kp100l avec et sans éthanol
surprenant comme baisse de rendement
en plus ça coute le même prix, aucune économie pour le consommateur
Messagepar Charles » Lun 19 Déc, 2016 18:51
Bah, de toute manière Trump a dit qu'il abolirait l'EPA.
Messagepar Mach Diamond » Lun 19 Déc, 2016 19:53
Il peut se le permettre puisqu'il a aboli le réchauffement climatique.
Mach Diamond
Modèle de l'avion: DA40
Messagepar Louis_greniier » Mer 21 Déc, 2016 11:52
Hélicopter a écrit: A powerful lobby of U.S. corn producers maintains constant pressure to increase ethanol volumes..
On fait porter le chapeau de l'éthanol un peu trop vite aux fermiers. C'est avant tout Monsanto qui bénéficie du transferts de la production des terres agricoles vers des semences qu'ils contrôlent à 100% comme celle du grain pour l'éthanol. Les fermiers pourraient cultiver autre chose, eux.
Je ne sais pas comment ils vont faire pour l'hiver et L'Alaska. Beaucoup d'autos ne passent pas le test de leurs catalyseurs au froid. Leurs émissions deviennent polluantes à certaines températures. Et l,EPA est quand même supposé protéger l'environnement. Pas le détruire en privilégiant une industrie spécifique.
bof, on verra ce que Trump peut y faire. Si il est proche des pétrolières, et plus logique question environnement, il va peut-être faire sauter ce crisse d,éthanol qui ne sert en rien à l'environnement.
Messagepar ttq » Mer 21 Déc, 2016 17:39
on est bien d'accord Louis......
Messagepar toxedo_2000 » Lun 26 Déc, 2016 13:17
Ben oui, ça l'air qu'il va falloir convertir les moteurs pour le charbon. J'ai même pas la place pour transporter une pelle dans mon hélico !!!
Messagepar bush pilot » Lun 26 Déc, 2016 15:01
Ost... D'éthanol de M....
Sur une note plus positive !!
J'ai vue des vidéos de ktm motocross Electrique et de vélo électrique assez surprenant
Je ne pensais pas qu'on pouvais faire des weele avec de l'électrique .
Vla quelques années c'était impensable. Ça commence à être intéressant
Aussi vue des ulm
bush pilot
Marque de l'avion: Pégazair
Messagepar Bob Cadi » Lun 02 Jan, 2017 15:06
Hé Louis...
Hier alors que j'étais pris dans un Time lapse à lire une Time capsule, je suis tombé la dessus...article qui date de 1935.
Peu importe l'époque, il y a toujours quelqu'un qui veut mettre quelque chose dans notre gaz...
Messagepar Charles » Lun 02 Jan, 2017 15:13
Sauf que dans ce cas-ci, on serait preneur. L'additif du Ethyl Gasoline est le bon vieux tétraéthyle de plomb (TEL), l'additif qui donne le plomb dans le 100 LL.
