La fin des ELT 121.5, es-t-elle proche pour le CANADA?
Messagepar VMF-214 » Mer 19 Déc, 2018 16:24
Selon un article d’AVWEB, la « Federal Communication Commission (FCC) des États-Unis, ne permettra plus de certifier et de vendre des ELT de la fréquence 121,5 Mhz après le 11 janvier, 2019! La fabrication, importation et vente d’ELT de la fréquence 121,5 Mhz sera interdite six (6) mois après le 11 janvier, 2019 (11 juillet, 2019)!
Lire l’article en anglais seulement, ci-joint!
Sale and Certification of 121.5 MHz ELTs Prohibited.
BY KATE O'CONNOR (AVWEB)
The Federal Communications Commission (FCC) issued a rule prohibiting the certification, manufacture, importation and sale of Emergency Locator Transmitters (ELTs) that operate only on 121.5 MHz last week. Similar rulemaking was issued in 2010, but at the request of the FAA and the Aircraft Owners and Pilots Association (AOPA), the Commission stayed the amendment prohibiting 121.5 MHz ELTs.
The new rule lifts the stay on prohibiting certification, manufacture, importation and sale of 121.5 MHz-only ELTs, but does allow for the continued operation of existing units. Certification of new 121.5 MHz ELTs is prohibited effective Jan. 11, 2019. The prohibition of manufacture, importation and sales will go into effect after a six-month transition period.
“This will accelerate the transition to 406 MHz ELTs and, as a consequence, enhance the ability of search and rescue personnel to locate and bring aid to the victims of plane crashes and provide safety benefits to search and rescue personnel as well as pilots and passengers,” the Commission said. “The record demonstrates that 121.5 MHz ELTs were clearly inferior to 406 MHz ELTs due to interference and other concerns even prior to the termination of satellite monitoring of 121.5 MHz, and that the advantages of 406 MHz ELTs have increased since then.”
The international Cospas-Sarsat search-and-rescue program stopped monitoring 121.5 MHz in 2009 due to reliability and false alert concerns. Along with other Cospas-Sarsat participants, the National Oceanic and Atmospheric Administration, U.S. Coast Guard, U.S. Air Force and NASA have been advising users to switch to 406 MHz ELT units for nearly a decade. The FCC also noted that the cost of 406 MHz ELTs had dropped to the point where “[it] does not appear that removing 121.5 MHz ELTs from the marketplace will impose significant costs on users in terms of a future price differential between 406 MHz ELTs and 121.5 MHz ELTs.”
Re: La fin des ELT 121.5, es-t-elle proche pour le CANADA?
Messagepar tonyb » Jeu 20 Déc, 2018 09:42
Le 121.5 va demeurer la fréquence d'urgence pour les communications radio j'imagine?
Dans la check list on n'aura plus a passer à 121.5 pour voir si ETL est déclenché par erreur.
tonyb
Messagepar toxedo_2000 » Jeu 20 Déc, 2018 13:00
Et qu'est-ce que je fais avec la montre Breitling sur 121.5 :wtf:
Messagepar Ben Blais » Jeu 20 Déc, 2018 13:12
toxedo_2000 a écrit:Et qu'est-ce que je fais avec la montre Breitling sur 121.5 :wtf:
Bon pour le MUSÉE !!!! :o
Benoit
Ben Blais
Modèle de l'avion: 180B
Identification de l'avion: Vendu
Messagepar toxedo_2000 » Jeu 20 Déc, 2018 14:11
10,000$ aux vidanges ? :thumbdown: :thumbdown: :thumbdown: :thumbdown: :thumbdown: :thumbdown: :thumbdown: :thumbdown: :thumbdown: :thumbdown:
Messagepar Zico » Jeu 20 Déc, 2018 15:29
tonyb a écrit:Le 121.5 va demeurer la fréquence d'urgence pour les communications radio j'imagine?
C’est ça (d’après ma compréhension de ma dernière MAJC). Daniel Delta Mike pourra nous en dire plus la dessus.
Messagepar VMF-214 » Jeu 20 Déc, 2018 17:52
La fréquence 121,5 Mhz devrait restée la fréquence de communication d'urgence, pour les aéronefs civile. Car les aéronefs civile, n’ont ordinairement pas la fréquence 243,0 Mhz (qui est celle militaire) et n’ont ordinairement pas la nouvelle fréquence 406,0 des radio balise d’urgence (ELT).
Messagepar VMF-214 » Jeu 20 Déc, 2018 17:59
Gaston,
À moins que les "Russes" utilise encore des satellites pour capter 121,5 Mhz ou que « Breitling » eu on des satellites pour capter 121,5 Mhz.
Alors, ta montre n’est plus bonne depuis 2009 pour le transmetteur d’urgence (ELT).
Messagepar DeltaMike » Jeu 20 Déc, 2018 19:31
Les ELT 406 MHz ont un émetteur 121.5 MHz pour fin de radiolalliement à une puissance relativement faible. Bien que les satellites n'écoutent plus 121.5 MHz, les lignes aériennes sont souvent à l'écoute de la fréquence. J'ai un ELT 406Mhz et j'écoute toujours 121.5 MHz au départ et à l'arrêt moteur.
La fréquence 121.5 MHz demeure la fréquence de communications radio. En cas d'écrasement, si un appareil de recherche et sauvetage vous survole, il tentera de communiquer avec vous sur 121.5 MHz.
Messagepar toxedo_2000 » Jeu 20 Déc, 2018 22:20
Gaston,
Qu'est-ce que je fais ? Je demande un remboursement ? :?:
Louis, qu'as-tu fait de ta montre ?
Messagepar VMF-214 » Ven 21 Déc, 2018 11:31
DeltaMike a écrit:Les ELT 406 MHz ont un émetteur 121.5 MHz pour fin de radiolalliement à une puissance relativement faible. Bien que les satellites n'écoutent plus 121.5 MHz, les lignes aériennes sont souvent à l'écoute de la fréquence. J'ai un ELT 406Mhz et j'écoute toujours 121.5 MHz au départ et à l'arrêt moteur.
DeltaMike et Gaston,
Comme dit « DeltaMike », c’est vraie que plusieurs des radiobalise 406 MHz on émetteur 121,5 MHz. Je ne sais pas si tous les radiobalise 406 MHz en on un? Certain ELT 406, ayant un émetteur 121,5 MHz, l’émetteur 121,5 MHz déclenché, va fonctionner pendant 50 secondes avant d’avoir la première émission sur 406 MHz. Donc raison de plus pour ne pas enlever l’action sur la liste de vérification (Check List).
Donc Gaston, maintenant tu compte sur les lignes aériennes (Airlines) et les aéronefs civils, pour te repérer avec ta montre ou que tu sois près d’un aéroport/aérodrome/…
Je croix qu’actuellement la branche des Forces Armées Canadienne soit, Recherche et Sauvetage (Search & Rescue) utilise les fréquences de 121,5 et 243 MHz près du lieu de l’émission pour trouvez la balise. Car je crois qu’ils n’ont pas été mis à jour pour la fréquence 406 MHz? Ai-je raison « DeltaMike »?
Messagepar kebek » Ven 21 Déc, 2018 14:53
http://fr.worldtempus.com/article/breit ... -4358.html
En attendant tu peux lire l’heure :mrgreen:
kebek
Messagepar DeltaMike » Ven 21 Déc, 2018 17:53
VMF-214 a écrit:Je croix qu’actuellement la branche des Forces Armées Canadienne soit, Recherche et Sauvetage (Search & Rescue) utilise les fréquences de 121,5 et 243 MHz près du lieu de l’émission pour trouvez la balise. Car je crois qu’ils n’ont pas été mis à jour pour la fréquence 406 MHz? Ai-je raison « DeltaMike »?
On ne peut faire un radioralliement sur un signal qui est émis seulement aux 50 secondes ( le Hexcode numérique émis par le 406 Mhz ). C'est pourquoi il faut qu'il y ait un signal sur 121.5 Mhz pour le radioralliement lorsqu'on approche de la zone de la balise. L'équipement de radioralliement de CASARA/SERABEC est en VHF seulement.
Une balise 406 Mhz sans GPS va donner une position à moins de 2 NM de sa position. Lorsque combiné à un GPS la précision sera autour de 49 mètres. Même avec cette précision la confirmation visuelle n'est pas toujours évidente comme en témoigne la photo.
Messagepar denimich » Ven 21 Déc, 2018 22:15
Presque tous les aéronefs militaires canadiens ont une écoute permanente sur 121,5 lorsqu'en vol et la majorité peuvent faire un radioralliement sur 121,5.
Les radios des aéronefs que j'ai pilotés avaient sur leurs radios les positions OFF; T/R et T/R+G. À la position T/R+G l'équipage est à l'écoute de 121,5 peu importe la fréquence sélectionnée.
Denis +30°C c'est mieux que -30°C
Messagepar toxedo_2000 » Sam 22 Déc, 2018 00:39
Ça ne m'avance pas... à moins qu'on soit à l'heure avancée... :oups:
Messagepar LIO » Sam 22 Déc, 2018 13:08
Gaston
bonne nouvelle
elle se fait en 406 mhz
https://www.breitling.com/fr-fr/watches ... BC02-159E/
LIO
Marque de l'avion: Helio Courier
Messagepar toxedo_2000 » Sam 22 Déc, 2018 13:13
LIO a écrit:Gaston
bonne nouvelle
Je le sais, mais c"est ti possible de mettre juste un "upgrade" sur la mienne?
J'ai été con quand on a crashé, il y a 6 ans avec le Wilga. J'aurais dû la déclencher. Il est prévu que la remise à neuf est gratuite quand son ELT est activé lors d'un accident aérien. :problem:
Messagepar LIO » Sam 22 Déc, 2018 18:33
LIO a écrit:Gaston
bonne nouvelle
la nouvelle est tellement grosse que tu as le bras 2 pouces plus long apres une semaine je l ai essayer a Genève j avais pas le poignet assez gros et le porte-feuille non plus lol
LIO
Messagepar bush pilot » Lun 24 Déc, 2018 16:07
LIO a écrit:Gaston
bonne nouvelle
Je peut t'arranger ça si tu veut !!
veutu faire une tite ride en caddy dans les vacances ? :mrgreen:
bush pilot
Marque de l'avion: Pégazair
Messagepar toxedo_2000 » Mar 25 Déc, 2018 12:42
bush pilot a écrit:
Je peut t'arranger ça si tu veux !!
veux-tu faire une tite ride en caddy dans les vacances ? :mrgreen:
Non merci. Une fois c't'assez ! :mrgreen:
Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 3 invités
