Encore une tuile sur les BOEING 737 MAX!
Messagepar VMF-214 » Lun 17 Avr, 2023 09:01
Un des ‘’Contacteurs (Spirit Aerosystems)’’ à installé ‘’Incorrectement’’ des pièces sur des fuselages de certain ‘’Boeing, 737 MAX’’! Ces pièces, se sont les ‘’Raccords entre ‘’l’Empennage au Fuselage’’! Une petite défectuosité!!! Cependant, Boeing est en train de préparer une ‘’Inspection’’ et une ‘’Directive de Navigabilité (Airworthiness Directive (AD)) est en train d’être préparré, par la ''FAA''!
J’ai une pensé, pour ceux qui prendront un ‘’737 MAX, construit entre 2019 à aujourd’hui (selon Boeing, il on produits environ 400 appareils par année, soit peut-être 1,200 avions en service!
Voici un ‘’Article’’ en anglais ‘’d’AvWeb’’ :
Lien Internet : https://www.avweb.com/aviation-news/max ... ingID=1312
MAX Deliveries Affected By Manufacturing Issue
By: Russ Niles - Published: April 15, 2023
Boeing has stopped deliveries of some 737 MAX airliners after the discovery of noncompliant parts in structures supplied by contractor Spirit Aerosystems. Reuters is reporting that the issue is with fittings that attach the tail to the fuselage being installed incorrectly. “We have notified the FAA of the issue and are working to conduct inspections and replace the non-conforming fittings where necessary,” Boeing said in a statement. The FAA has accepted Boeing’s assessment that there is no safety-of-flight issue and the in-service aircraft can continue flying.
However, the issue has derailed Boeing’s plan to ramp up production to 38 a month from 31 and to deliver up to 400 MAXes this year. “We regret the impact that this issue will have on affected customers and are in contact with them concerning their delivery schedule,” Boeing said. The FAA is getting an AD ready to address the issue. It will likely include aircraft produced as early as 2019. Boeing shares dropped 5 percent and Spirit Aerosystems lost more than 11 percent on the news.
Mes deux cents,
Re: Encore une tuile sur les BOEING 737 MAX!
Messagepar GOTS » Mar 18 Avr, 2023 12:42
Merci Jacques, très intéressant. J'ai regardé le documentaire de BOEING sur Netflix récemment et c'est fascinant de voir comment l'avarice peut dicter des comportements tellement dangereux.
GOTS
Marque de l'avion: AutoGyro
Modèle de l'avion: Cavalon 915IS
Retourner vers Vols prévus et évènements aéronautiques
Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 66 invités
cron
